Manual Torque Converter Lock-up
#23
on
Well.. I've put a tank of fuel through her and I seemed to have gained 1.12 mpg..... I think I can improve this... as I used it sparingly for the first 100 miles...
the shifts seem some... if you time it correctly, it almost like your driving a manual.... acceleration improved
I can idle thru town at 25mph or cruise at 40mph @ 1,000 rpm
#25
Here is "smart" solution for manual TC lock.
I was thinking about adding manual switch to and I did but the problem is sooner or later you will forget to turn it off before stop . So after it happened to me few times I decided to do something.
After googling for a while I only cold find 2 solutions expensive buy control or cheap switch.
I didn't like both of them and made 3 one. It cost me about $20+time.
I will post step buy step solution in next few posts. Please hold on let me finish it to avoid mess.
#26
#1 List of materials
1. Arduino UNO. (eBay)
2. Arduino relay (eBay) or just 5V relay from scrap electronics....
3. Power supply for my old usb handsfree. (12v-5v)
4. op-amp amplifier. I found one in old bread maker AZ358
http://junwellcorp.com/Attachment.ph...rp.com.cn/pdf/
#4 can be LM128 or LM358 or probably many other op-amps.
5. Some wires.
5. Some wires.
#27
#2 My truck
My truck is Ram 1998.5 5.9 24v diesel.
1. I found how to add manual switch here:
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
2. I used speed sensor which is located on top of rear differential. The 2 wires come straight to ABS module in engine bay. (will post colors later).
The signal from speed sensor is low voltage, so I used op-amp amplifier to boost it. (see post # 26 #4.)
#28
#3 Wiring what where how
First and the most complicated part is op-amp. Here in this pdf find page #2 "Pin Configuration"
pin 1 output goes to pin #5 on Arduino board
pin 2 and pin 3 are 2 wires from speed sensor doesn't matter + or -
pin 4 ground goes to pin ground Arduino
pin 5,6,7 nothing
pin 8 +5 v from Arduino
Power supply can be any 5V USB car charger. I just soldered + and - to Arduino board.
I bought relay for Arduino but 5V relay can be found just about anywhere. I used pin #8 on Arduino board to turn relay ON/OFF.
I still have manual switch which can turn off TC lock manually even if Arduino keeps it locked. Here is handy for heavy towing.....
I also added LED which shows TC status Locked-ON Unlocked-Off
pin 5,6,7 nothing
#29
#4 Software
Just google Arduino and see what you need to install to make it work. Arduino soft is open source and FREE.
Also you need to read this if you like:
http://interface.khm.de/index.php/la...unter-library/
I used their code and just changed few things....
You need to Download >FreqCounter Library:
http://interface.khm.de/wp-content/u...unter_1_12.zip
You need to add this Library to make code work. Here what to do:
http://arduino.cc/en/Guide/Libraries
#30
#5 Code
#include <FreqCounter.h>
const int relayPin = 8;
void setup() {
// initialize serial communication at 9600 bits per second:
Serial.begin(57600);
Serial.println("Frequency Counter");
pinMode(relayPin, OUTPUT);
int torqLock=1875;
int torqUnlock=1700;
long int rpm;
void loop() {
FreqCounter::f_comp=12; // Set compensation to 12
FreqCounter::start(1000); // Start counting with gatetime of 100ms
while (FreqCounter::f_ready == 0) // wait until counter ready
rpm=FreqCounter::f_freq-FreqCounter::f_freq/500; // read result
Serial.println(rpm); // print result
//delay(1);
if (rpm < torqUnlock) {
// Unlock Relay off: HIGH
digitalWrite(relayPin, HIGH);
else if (rpm > torqLock) {
// Lock Relay on: LOW
digitalWrite(relayPin, LOW);
void setup() {
int torqLock=1875;
long int rpm;
void loop() {
//delay(1);
