Best Gear Ratio?
Old 07-10-2012, 12:19 PM
Ramingo's Avatar
Ramingo
Ramingo is offline
Okay this is confusing, since iv pulled (sand rail & quads) with my 35's and 37's with no problem.. Then again iv got the Offroad edition truck which came with factory 4.10s, i wonder what will happen if i go with 4.56
  #22
Old 07-10-2012, 12:26 PM
lastrights's Avatar
lastrights
lastrights is offline
U would wanna go 4.88
  #23
Old 07-10-2012, 12:27 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
I recently went from 3.92 to 4.56 what would you like to know?
  #24
Old 10-21-2014, 12:29 AM
Tyler Jenkins's Avatar
Tyler Jenkins
Tyler Jenkins is offline
New Member
Default Gears
I got a 01 sport with a 318 on 38s what would be a good gear ratio to be able to haul a 16 ft trailor with a jeep xj. Lookin to keep as good of fuel milage as possible but not struggle to pull the jeep.
  #25
Old 10-21-2014, 02:00 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
5.13 gears if you have Dana 60 axles. If you still have the stock axles on 38" tires I would look into swapping them out for D60 axles.
4.56 is the lowest you can get right now for your 9.25 rear axle.
  #26
Old 10-21-2014, 02:35 AM
Thornloe Pride's Avatar
Thornloe Pride
Thornloe Pride is offline
+1 on 5.13s with 38s.
I'm guessing because you have a 318 that you have a 1500? You are playing russian roulette with half ton axles on 38s.
Wildman, I thought you could get 4.88s for the 9.25 rear?
  #27
Old 10-21-2014, 10:21 AM
Tyler Jenkins
New Member
Okay thanks. I wasnt looking to change axles so how would 4.56s do on gas, pulling a jeep and on the highway? I live in wv and theres a bunch of hills i hafta go up to take it places.
  #28
Old 10-21-2014, 11:19 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
You have 38 in tires. With 4.56s you will STILL be at taller ratio than stock.
It's not 30 in tires with 4.56s........
Have to take tire size into account. It's not just gear ratio. 4.10s with 50 in tires you would never get the thing going.......
Your truck would still be a dog with those gears. Albeit a litter better one
  #29
Old 10-21-2014, 01:32 PM
Wildman4x4nut
There was 4.88 gears but they have stopped production of them.
He is 100% correct that you're pushing your luck with stock axles and 38" tires. Go to a junk yard and find some D60 axles for your truck and swap them out. Then when you're at it swap in 5.13 or 5.38 gears.
I know you were not looking to swap axles but if you want to keep your truck running right you need to swap axles.
  #30
Old 10-21-2014, 09:18 PM
Thornloe Pride
4.56 would definitely feel better than the gears you have now (guessing you have stock gears?) but you are still way under geared and to buy 4.56 or the proper gear is the same price so why not get the proper gear right? 4.56 would not make it easier on gas because you are still not in the proper rpm range and it would suck for towing. 4.56 brings you back to stock mileage, power etc if you had 35s. 4.88s for 37s. Because you have 38s AND you are towing in a hilly area I would get 5.13s for D60 axle. Maybe even 5.38s. Don't fear the gear. The thing would be a BEAST and I would put money on your gas mileage being better than it is now and your transmission would thank you. I know it sucks to do an axle swap but trust me, it will pay off. Heck I broke an axle shaft with 35s and it was fluke. Now I'm upgrading to 38.5s and guess what, I'm doing an axle swap as well.
Quick Reply: Best Gear Ratio?
