Leaking Transmission. Not Pan!
Old 07-15-2012, 10:29 PM
RaissiKitten's Avatar
RaissiKitten
RaissiKitten is offline
Whoops.. didnt see you posted it. LMAO. I tried to pull those torx out.. OMG they are on their tight!!! Im almost afraid I will bust them.. I hear you should inspect that spring when your in their anyway.. So, I may bolt it back and go that route..
  #22
Old 07-15-2012, 10:46 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
i just replaced all 3 sensors on friday evening. i removed the side piece like stewie said(gotta love the search feature) one spring came out from the side. the torx bits are in the pretty good, but i just went and bought a t20 torx socket, and they came right out without a problem!
  #23
Old 07-15-2012, 10:54 PM
RaissiKitten
Well, heck with it them. Ill put the six bolts back and take off the side plate. Now, I did get the gear and throttle linkage loose, do I just pry them back on and put the bolt back in? I dont want these suckers loose..
  #24
Old 07-16-2012, 09:03 AM
stewie01's Avatar
stewie01
stewie01 is offline
So, any update on how this went?
  #25
Old 07-16-2012, 11:38 AM
RaissiKitten
Not yet, it was to dark last night to mess with anything (My truck is to big to fit in the garage.. lmao) So Here in about an hour I am going to get into it again. I did Bolt the VB back up, here in a few I will take the plate down and let you know. I wont be able to drive it again until this evening.. My husband is bringing home ATF4 for me.. I appreciate the help though, Seems like I always pick the hard ways. Haha. Thanks. Update soon!
  #26
Old 07-16-2012, 11:44 AM
redneck_ram
wow another female on the forum, kudos to you!
  #27
Old 07-16-2012, 11:45 AM
RaissiKitten
Haha, Thanks. Been doing Mechanic work for about 5 years now.. Just not transmissions!
  #28
Old 07-16-2012, 11:57 AM
redneck_ram
transmissions arent all that bad. just takes learning to a whole new level!
  #29
Old 07-16-2012, 12:59 PM
RaissiKitten
Im finding that one out! Ok, Here's the update. Not good. The plate isnt going anywhere. I tried to take the torx out, and it stripped, the second started, so I said forget it. Im finding alot of things on way to tight on this sucker.. I was afraid to spray them down inside the transmission like that.. So im gunna have to drop the VB.. The only thing holding the VB right now is that stinkin' Throttle Linkage.. I got the bolt out, and the gear shift linkage loose, but its not going anywhere until the throttle linkage does.. It seems like there is a pin that runs through it into the VB.. Any ideas? I got the spring off of it..
  #30
Old 07-16-2012, 01:03 PM
RaissiKitten
And I just did some research.. That pin is supposed to have a e clip? Yeah, Not mine. Uh oh.
Gunna go double check real quick.. If not Ill take a picture. >.<
Quick Reply: Leaking Transmission. Not Pan!
