4x4 problems 4L. ok , 4h. wont engage help
#21
#22
ok : problem to run your test Hey you is , the truck does not go on 4H . that is the lever stops on 2H. and does not go past that , some days ago one of the boys sugested checking the lever on the transfer case to see if it has moved from position and it has not i took it appart anyway loosing the bolt and asked my son to go on top and hold it on 4L. and it was the same no change discarting the posibility of the lever just not going far enough to engage 4h. let me know what else we can try , thanks
#23
#24
#26
#27
#28
#29
i don't know what is wrong, but if its not the shifter or shifter linkage binding up, then its something inside the tcase.
did you disconnect the shift rod from the t-case and try to shift the t-case lever manually? its a little green press-on plastic connector that just pops off. if you haven't tried that yet, do so.
the vac switch can be seen in the 3rd pic. i doubt that that little push ball has anything to do with the problem.
https://dodgeforum.com/forum/2nd-gen...31-np231d.html
#30
Alright guys promise me you all not, I say (NOT) to laugh . found the problem its 12:35 am and I just had to tell you . last week I removed the rug to be replaced and received the new one shortly after installed the new rug man a perfect job however did not noticed that one of the bolts holding the shifter plastic oval enclosure dropped under the shifter , I thought that it was just a single sheet of metal separating the inside of the truck and the outside of the truck well is not where that shifter plays up and down there is a double pocket the bolt dropped in and could not go anywhere it is totally enclosed so when the shifter goes backwards the bolt would not permit it to go past neutral . man I was starting to worry real bad , thank you all for your combine experince and the patience to deal with all of these , thanks again really appresiate all your time
