what did seafoam do to my truck?
Well my truck had been real sluggish&just alpe going...its always been like that.Theres a huge hill out here&when going up it I floor it&its a dog Wont go past 50&its a long steep hill.Well I ran seafoam throug my brake booster line&now its running like a raped ape!The same hill I can fly up no problem.It runs great has never ran this good.I bought it with 125xxx now has around 132xxx Im guessing I must have some filthy injectors Ove been replacing alot of stuff lately&it seems as if all of the sensors &everything else is stock.
I know the p.o. kept up with regular maintance buy guess nithing started failing till I got it.
Your plenum is blown...the seafoam may have plugged up the plenum leak temporarily and its not leaking air anymore
Thats my guess on what happened because one can of seafoam wouldnt make a night and day difference like that....but i can guarentee your plenum is blown and its starting to take out your catalytic converter and thats why its sluggish...
You guys have gone plenum crazy!Every post I read when someone has an issue simeone says your plenum is blown!....Not mine Ive already did the fix with the aluminum pan back in march &gutted the cat shortly after that &did new plugs,wires,cap ,rotor,comp test ,air filter etc...so I can guarantee You...your guarntee is a fraud j/k but forreal it sucks
I cant see infos or sigs cuz im on my phone so if its posted sorry...
And its not fraud because you said its been changed so it was blown i was just late making my statement
Trending Topics
Well if you only ran a whole can just through your brake booster line, it didn't even reach inside your injectors to clean them! (just the outsides of the tips and thats a stretch!). If anything it cleaned the crap off your plugs,intake ports & carbon out of combustion chamber that was possibly causing it to ping and be a pooch. My plenum gasket was blown, 3 of my plugs were completely fouled (looked like they had the rusticles from the Titanic's bow growing out of them!) and I could still rape my tires & hills, though everything was much smoother after replacing that with zero chugging. I also did a full tune up with new cap,rotor,plugs & wires all at the same time I fixed my plenum so I don't know what had the biggest impact on performance all I know is that my truck loves to eat tires with any amount of sudden throttle past 1/8th and doesn't need a brake stand to make by-standers full of smoke.
As for Seafoam I always do what the can says which is: 1/3rd of the can is supposed to go into the fuel tank, 1/3rd into Engine oil and the other 1/3rd into a vacuum source (brake booster works,any vacuum line).
