95 Ram 4x4 318 engine interchange
Old 08-30-2012, 08:21 PM
wired1141's Avatar
wired1141
wired1141 is offline
Default 95 Ram 4x4 318 engine interchange
I have a 95 Dodge Ram 1500 4x4 with a 318 that blew up so rebuild is not a option, lol. What years and sizes will interchange without having to rewire or change the computer?
Old 08-30-2012, 08:50 PM
Aussimissa1024's Avatar
Aussimissa1024
Aussimissa1024 is offline
Honestly, Id just stick another 318 in there. Mopar really got it right, it can produce GOBS of power easily and since its a smaller displacement, it has the potential to get good MPG's. More displacement doesn't mean more power.
Old 08-30-2012, 09:52 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
any 94-01 Magnum 318/5.2
if the new engine is not a 94-95, move your 95 intake and all sensors to the new engine.
fix the plenum too.
Old 08-30-2012, 10:00 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
also watch out for the crank position sensor. those seem to like getting damaged when people do engine or transmission swaps.
Old 08-30-2012, 10:04 PM
wired1141's Avatar
wired1141
Thank you, I am looking for another engine and just don't know what will work.
Old 08-30-2012, 10:53 PM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
Like stated any magnum motor. If its not a 94-95 then all you have to do is swap your intake maniffold with all the sensors on it.
Old 08-30-2012, 11:25 PM
crazzywolfie
well you will most likely want to take the intake off anyway just so you can fix the plenum which will cause tons of problems in the future. engines are soo much easier to work on when they are not in a truck.
Old 08-31-2012, 08:46 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
It's just easier to extract more power from a larger engine.
There is no replacement for displacement.
Quick Reply: 95 Ram 4x4 318 engine interchange
