Oil pump changed, now wont start
does your 97 have the fuel pressure test port on the rail. check pressure and/or listen for fuel pump whine when ignition is turned on.
shade tree method for testing fuel pressure. put out cigarette. place rag over fuel pressure test port and press the little valve stem. high pressure gas will squirt out. catch in rag and clean up. avoid fire....
check for spark at the plugs.
check for 12v at the coil.
