Leveling Kit
Leveling Kit
I have a 2001 Ram 1500 Sport 5.9L Off-Road Edition and I am thinking about getting a leveling kit. I have the factory 1.75 inches of lift since it's the Off-Road Edition and then also have 3' body and 3' suspension on it too. I'm looking at getting a leveling kit though because how much lower the front end is drives me crazy. I'm looking at the one on hellbentsteel.com for a 2' leveling kit. Will this affect my performance in any way?
Edit; Unless the kit say's for off-road truck you must take off 1.75 inches from the kits height; IE a 5" kit will get you 3.25 inches of lift over what it was. I would also NOT be using spring spacers with lift coils, see warning below.
Under NO circumstances are SKYJACKER® coil springs to be used in conjunction with any type of
coil spring or spring tower block/spacer. The use of coil spring block/spacers will allow ANY coil
spring to exceed its designed stress and travel loads allowing it be overstressed, oversprung,
fatigued, and possibly break. SKYJACKER® warranty is void under any such application.
So basically, it can be done but requires the additional parts and labor. Just adds to the cost considerably. Without doing this part, your ride will not be satisfactory, will create excessive wear, and compromise safety - yours and others.
No one is trying to talk you out of lifting your truck - we just want you to do it safely.
Trending Topics
lolz Kejobe.
TheBigYoss, using " means inches and using ' means foot.
A pertinent question here is...what is the brand of your 3" suspension lift? If you don't know, can you post pictures here showing the following:
1. Trackbar, and it's connection to the frame
2. Control Arms
3. Top of your coil springs
2. Control Arms
