ok The plug that engages your ac unit on the driver side of the motor, I cant find were to hook this up. I had it in bypass with a peace of wire, and now i can find the other end of the harness. Any one have a idea were to look
There are 2 connections on that side. One plugs into the high pressure switch in the ac line as Arde stated. And the other one connects to the wire running behind the pulley to the clutch. That plug is in between the VC and intake manifold under or near the #1 injector.
