Dodge Ram 1996
Try this for the P0411:
http://www.ramforumz.com/showthread.php?t=93016
PO711 - Transmission fluid temp sensor Range/Performance
https://dodgeforum.com/forum/2nd-gen...nsor-code.html
BTW, Google is truly your friend in searching for information on PCM codes..
I think you mean p0441 not 411. Which is a problem in the evap system setting off the purge flow monitor. Check the hoses around the canister (big plastic thing on frame rail) and purge valve (plastic cylinder on one of the inner fenders) for cracks/holes/missing. The purge valve itself may be bad as well.
