Air Hammer strength to remove ball joints?
Old 05-23-2013, 01:09 PM
jesssed's Avatar
jesssed
jesssed is offline
Default Air Hammer strength to remove ball joints?
I'm going to be replacing my ball joints and last time I did this I was a dumb kid and didn't understand how rivets work. I've done my research now and decided to go the air hammer route.
Does anyone know what air hammer would be good for this job?
I looked at a Ingersoll 114GQC, will this be strong enough to pop off the head and then drive the rivet out?
If I do need something stronger what is the best for the price? I really don't want to spend too much on a hammer seeing I won't use it that often, but at the same time I don't want to have my truck all apart hook up the hammer and it doesn't do **** for removing my rivets.
thanks
Jesse D.
Old 05-23-2013, 01:39 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
You have a 2wd I assume. Add that info to your sig and profile. Anyway, I think grinding the heads off and popping the rivets with a punch and a regular hammer, would be easier. And grinders are pretty cheap and more useful.
Old 05-23-2013, 01:50 PM
Ezuh's Avatar
Ezuh
Ezuh is offline
Im just curious zman, I have a 4wd and tried doing mine a couple weeks back. Couldn't budge them at all. Snapped a wrench trying to turn it with a cheater bar. Ideas? Do they still have the rivets?
Old 05-23-2013, 01:55 PM
zman17's Avatar
zman17
zman17 is offline
Snapped a wrench turning what? The castle nut? You did remove the cotter pin right? You need a socket(impact) and a breaker bar or impact wrench. There are no rivets on a 4x4. And don't jack the guys thread. lol
Old 05-23-2013, 02:00 PM
Ezuh's Avatar
Ezuh
Ezuh is offline
Not trying to buy we were using a balljoint press, and we didnt could get the truck up high enough to get an impact on it, so we had a wrench on the press turning it with a cheaters bar, which then broke. As for the cotter pin, where is that?
Old 05-23-2013, 02:08 PM
zman17's Avatar
zman17
zman17 is offline
The cotter pin would have been on the nut, which it seems you have already gone past that. Are you using the correct size adapters for the press? And you still need better tools. Also while tightening, smack the side of the housing with a hammer. Sorry for the jack OP.
Old 05-23-2013, 02:10 PM
Ezuh's Avatar
Ezuh
Ezuh is offline
Yeah. So basically use some wooden blocks and jack it up higher and use an impact? Literally we also broke a 1/2in breaker bar trying to get it out to. They are literally like rusted in I think.
Old 05-23-2013, 02:15 PM
zman17's Avatar
zman17
zman17 is offline
Sorry, dbl post for some strange reason.
Old 05-23-2013, 02:16 PM
Ezuh's Avatar
Ezuh
Ezuh is offline
yeah we used correct adapters. Thing would not budge at all.
Old 05-23-2013, 02:23 PM
jkeaton is offline
Dodge Forum Administrator
thanks
Jesse D.
Easier to either grind the heads off as zman said or drill them out like I did. Air hammer is overkill, imo.
Quick Reply: Air Hammer strength to remove ball joints?
