Significant gas mileage drop since plenum fix... Why ?
#41
Your setup sounds like mine. Whoever deleted my check valve cut it out and clamped the rubber hose to the hardline, I haven't had a problem in the 1 1/2 yrs. I've been driving it, no hose blowing off or anything. Doubt there's enough pressure in that line to be a problem.
I lightly rev mine in N after a cold start in the morning. Sometimes I don't have too and It'll go, but not far. Doesn't sound like you have a problem, just a slight inconvenience from the lack of a check valve. Adding an external filter will take care of it if you don't like the inconvenience. But do as Hey You says and pull the line and check it.
#42
If I remember right, one of the mods in a shift kit allows lubrication in Park. You replace the manual valve and grind off a bit of the body itself.
MY TJ trans is real bad, never did a shift kit. Always have to shift to Rev to get any gear. But the 44RE in my Wagoneer doesn't seem to have thatn problem.
#44
#45
#46
I dont think I want to unscrew the metal cooling lines from the transmission.. Its been in there for 15 years and i really dont wanna have leaks or break something i've heard a lot of horror stories about these cooling lines.
Anyway... I wish i could figure out why im getting great mileage on the freeway, but horrible in the city.. The needle drops sooooo QUICKLY in the city it sucks... I dont get IT !! im deff not running rich i dont think.. the tail pipe is SOO clean now since my plenum fix i dunno if your familier with how BLACK and sooty the tailpipes get when your burning oil.. but man mine when you swiped your finger on the inside egde was thick and black like a oil burning furnace.. Now its like spotless after 1500 miles.... Soo frustrating.. Im thinking about taking my K&N FIPK off and see if the stock intake helps it some..
I think Im gonna try putting 89 octane in the tank as well.. Since my pinging seems to be gone now.. The Jeep 5.9 engines like i mentioned required 91 and 92 octane (for the Performance mopar PCM) its different then you dodge guys who can use 87.. I wonder if i can get away with 89 now.. Altho 89 is lower then 91 it might ping ill run it near empty fill it up little over quart of a tank and see if not ill put 93 back in. I remember when i was burning oil and i put 89 in... Omg between it burning oil and pinging and the lower octane then what was recomended.. it pinged like a **** scared me actually haha
I plan to get new O2 sensor tomorrow as well.. I just hope i can get the old one off without hassles lol.. So NGK are good O2 sensors ? No like check engine bull**** 20 miles later ?
#48
#49
Im talking about removing the line from the bellhousing.. Im not doing that.. If your talkin about removing the rubber line and looking inside the end with the check valve then yea i can do that.
Anyway do you guys know what the part number is for the NTK o2 sensor ? They had a bunch of diff ones, and $55 seems like a lot to me am i wrong ? I need the upstream one right ?
