Pinging under load/ aftermarket intakes manifolds
I dont know if there is an intake with better low end that the kegger. That is ALL it has. The M1 is great, and with the right complimentary mods you will improve the low end and gain massively in the upper range.
On a stock engine though, you will lose a little low end
On my Dakota I've gone from a 2bbl M1 to a 4bbl M1 and now I have an Indy 360M intake all in the quest for more top end speed, but my converter has increased as well...4000K now
Want the power to come on right away with a stock converter...Stay with a stock manifold. It's pretty hard to have a manifold discussion only...It's a sum of all parts.
It moves the power band up...I'm building my Ram for torque so I'm staying with the stock manifold.
Kegger is better for bottom end due to runner length. Those long runners promote air flow at lower RPM. Of course, they also choke it off at higher RPM.
The M1 manifold is a single plane, short runner manifold. Designed more for mid-range, to high rpm. The two barrel flavor will give somewhat better response on a truck motor due to the SMALLER plenum area. (velocity over volume) Basically, with a two barrel throttle body on there, it fools the engine into thinking the runners are longer than they really are.
An M1, (2bbl) with proper supporting mods will actually give you MORE bottom end, then the kegger..... These motors in stock form are seriously under powered.
^^ This.
I guess I will be repairing the stock intake if there is not benefit to replacing it. Is the hughes intake repair kit the way to go? also since I will be saving money by not buying a new intake I want to put it into an electric fan and spectre intake system. Has anyone been able to increase their mileage by doing this? Even if I picked up 1 mpg it would help quite a bit.
The members here who are running the hughes arent as active as those with the m1...as far as I know, it takes a bit more work to install it and the fitment isnt always 100% perfect...but those who have it seem to like it. hughes does provide a link to a pretty good step by step install procedure from some guy with a durango. i still can't make up my mind as to which i want, i go back and forth daily between the two.
