Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram Tech
Sign in using an external account
Register Forgot Password?
97 Dodge Ram 1500 transmission slipping
Thread Tools Search this Thread
Old 08-05-2013, 08:28 PM
wldcat1969 wldcat1969 is offline
Default 97 Dodge Ram 1500 transmission slipping
I have a 97 Ram 1500 with a 5.2L V8 and the 46RE automatic transmission.
Recently the transmission started acting up and I just want to see if people agree with my possible diagnosis before I pull it apart (not looking forward to that).
When I come to a stop then start up again, it acts just like a manual transmission where the clutch slips. I hear the engine rev up but the transmission is not engaged. Then after reaching a certain RPM it will engage and take off. And it's just like I popped the clutch, it jolts hard and sometimes even squeals the tires. Additionally, when going down a steep hill the transmission will seemingly shift down then back up causing the truck to almost pulse down the hill if I'm off the gas. Sometimes if I give it gas and rev the RPMs back up it seems to be alright.
The check engine light is not on and I changed the output speed sensor a few months ago when it was having slipping problems but that fixed the problem at the time. I don't think it's that sensor because the light is not back on and the problems are not quite the same.
My best guess is to change the governor pressure sensor and solenoid. I did check the fluid levels and they were good, but I did it in park so I'll try it again in neutral tonight and see if that makes a difference.
Anyone agree or disagree with this? I'm hoping it's something simple and not going to cost me a ton of $. I am in the military and can take it to the auto shop where I can do it myself so hopefully it's something I can do myself.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Old 08-05-2013, 08:40 PM
xplorer82's Avatar
xplorer82 xplorer82 is offline
Vehicle: '98 Ram 1500 SLT 2wd 5.9L
first thing I would do as its simple and easy, check the TV cable on the throttle body, and adjust if there seems to be slack.. its better to have someone with you and check both, the lever at the transmission and the throttle body lever and make sure they move simultaneously. iirc there should only be 1/32" difference between the two.
__________________
┌П┐(-_-)┌П┐
Bud Light - '98 Ram 1500 SLT, 5.9L, 2wd, 152k miles, Double roller, aFe Pro Dry S, Flowmaster cat-back dual exhaust.
Old 08-05-2013, 08:47 PM
I should also add that it only does this after it's warmed up/hot. If the truck has been sitting for a day the transmission is fine for the first 10 minutes or so.
Old 08-05-2013, 08:48 PM
Paul DeHayes's Avatar
Paul DeHayes Paul DeHayes is offline
Vehicle: 99 Dodge Ram Laramie SLT 5.9L 360
I can agree with the TV adjustment, however the governor pressure solenoid is a problematic piece too, prone to dumping out under high line pressure. The Borg Warner HD unit works very well:
http://www.doghousediesel.com/catalog/i307.html
__________________
Old 08-06-2013, 11:39 AM
zman17's Avatar
zman17 zman17 is offline
Dodge Forum Moderator
Vehicle: 2000 2500HD 4x4 5.9
You might also try adjusting the bands. Get a Haynes manual and see if you have the correct tools to perform the procedure. You'll need to remove the pan for one of them. This will also give you the opportunity to see what is in the pan. Install a drain plug while the pan is off also.
__________________
2000 2500HD 4X4 5.9 and 4:10's,HF tuned SCT,Red-Head gear box, HS 1.7's,
50mm Fastman TB, Hughes Plate,2" Hell Bent ,Volant CAI
Flowmaster 50 series, Rock Solid Ram Steering fix,B&M trans cooler,fuzzy dice good for 5HP
Old 08-11-2013, 11:08 PM
Haven't been able to get under the truck because it rained most of the weekend. This afternoon I decided to check out the throttle valve cable but I'm not sure I completely understand what I should be doing.
According to the manual it says the cable end and attachment stud should be aligned to within 1mm in either direction. But I'm not sure which pieces should be aligned where. Is the attachment stud the piece on the lower right part of the throttle body lever? As you can see in this picture, there is a LOT of slack in the cable (both the short piece and the longer piece) but I don't know if that's normal.
Could this be causing my problems, and if so, how to do this adjustment? And specifically, since this only happens once the engine/transmission is warmed up, could the issue be this adjustment?
Thanks for any help! Here is a pic but there are more angles of the same thing if you view the album. If the image doesn't work just go to my Picasa Album here (https://picasaweb.google.com/karl.p....eat=directlink).
Click the image to open in full size.
Old 08-11-2013, 11:19 PM
I may have figured it out somewhat. See this picture (also in the album linked above). Is this what I adjust? And if so, then the slack currently in the line really doesn't matter?
Old 08-12-2013, 12:46 AM
dodge dude94 dodge dude94 is offline
Vehicle: 1998 Ram 1500 QCSB 360 4x4
You see that little box behind where you have the arrow?
There is a little white clip in it, you need to remove that guy and it will allow you to move the cable back and forth in that housing.
Only move the cable 1/8th to 1/4 of an inch. Then put the clip back in.
Old 08-12-2013, 06:52 PM
zman17's Avatar
http://dodgeforum.com/forum/2nd-gen-...-in-trans.html
__________________
Old 08-14-2013, 01:34 AM
Ok, I had a chance to check the TV cable today and I think it's good. I took a picture and as you can see, the center line seems to be lined up with the stud (no slack in the line but wasn't pulling either). Got the Borg Warner HD governor sensor and solenoid from Doghouse in the mail yesterday (thanks for the link Paul) so Saturday I will change those out (and the filter while I'm there). Never done it before but it seems pretty simple so I'll give it a shot
Here is the TV cable: Click the image to open in full size.
Old 08-14-2013, 08:58 AM
HeyYou HeyYou is offline
Section Moderator
Vehicle: 1996 Dodge Ram 2500
pic won't load for me... might just be my crappy internet connection.....
__________________
1996 Ram 2500 5.9 EC/SB Gas, Auto, 4x4, Hughes plenum plate, Kegger mod, double roller timing set, rest is stock. For now.....
Old 08-14-2013, 09:04 AM
stewie01's Avatar
stewie01 stewie01 is offline
Vehicle: 2001 Ram 1500 4x2 360V8
__________________
"This place is an X-file, wrapped in a cover-up and deep-fried in a paranoid conspiracy."
Old 08-14-2013, 09:10 AM
Section Moderator
Good Deal Stewie.
That looks just about perfect.
__________________
Old 08-17-2013, 07:04 PM
Ok, yesterday I put in the new governor pressure sensor and solenoid and changed the transmission fluid/filter. The truck definitely shifts better now but it's still not back to normal. After driving for 10 minutes or so it will still act like I'm popping the clutch when starting from a stop. So it will slightly rev up for a second then jump forward as it catches. Shifting between other gears seems normal but the one from a stop still is acting weird.
Then just to make it even more confusing, after I got home yesterday I parked it, put it in neutral and topped off the fluids. Then I took it right back out (I put a little bit of Lucas Oil in there so I wanted to mix it up) and it shifted just fine. Never shut it off so it was still hot but shifted just fine. So I decided to check 1st and 2nd. Put it down into 2nd to start and it did the same popping the clutch thing. Put it back in drive and it was back to popping the clutch. So just for the heck of it, trying to "clear" it somehow, I put it in neutral for a second, then reverse and backed up a couple of feet. Then back to drive and viola, it shifted just fine. I didn't try putting it back into 2nd. So I'm kind of lost now. Maybe it is a mechanical issue? I didn't clean the throttle cable assembly on the engine but it didn't look too dirty and seemed to move just fine. I checked the other end on the transmission and the spring is still there and it seemed to move without any issue either. It is kind of oily because I think it was leaking transmission fluid before I changed it but it still moved just fine.
Any other ideas? I'm trying to sell the truck but I can't in good conscience let someone buy it if I know there is an issue.
Old 08-18-2013, 11:16 AM
zman17's Avatar
Try adjusting the bands yet ? And you are checking fluid level in neutral right ?
__________________
Old 08-18-2013, 09:33 PM
Quote:
Yeah, I wondered about the bands too. I looked at them but to be honest wasn't sure how they were supposed to look. I noticed that one didn't look exactly like the other but not sure if that was normal. Here is a pic of them but I'm not sure if you can tell anything from the picture. Hopefully they don't need to be adjusted because I really don't want to take the pan back off again
And yes, was checking in neutral.
Here are the bands:
Old 08-19-2013, 01:38 PM
zman17's Avatar
You cant tell by looking at them. You have to adjust them. And this time when the pan is off, install a drain plug.
__________________
Old 09-05-2013, 09:23 PM
j.hunter1313 j.hunter1313 is offline
Default is my tranny slipping?
Hey guys, im new to the forum. I came here looking for some answers, so hopefully I can find them here!
The other day I drove my truck to work, and to lunch and back with no issues at all. Then when I go to head home, I put my truck in reverse to back out of the stall, and it made a pretty loud clunking noise, then would not move if i pushed on the accelerator. I put it into drive and I could move, put it back into R, and same thing. I was able to drive it home as long as I didnt have to put it into R. So the only area Im having the problem is in reverse.
I had a buddy who told me it was most likely my reverse gear was toast, or an unlikely chance, that it may be my linkage? any thoughts? thanks in advance.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Contact Details & Emails
