Still have shift issues
on
CHEAPEST way is to cut it out and replace with straight pipe. (What I did) Non fouler trick for the rear O2 to eliminate the CEL.
Feds require us to have a catalytic converter, but who cares about the Feds?
Replacement depends on local emissions laws in your area/state.
A Jegs Off Road Y Pipe is a good choice, or a MagnaFlow High Flow Cat.
But do check the plenum, if it's bad it will destroy another cat and O2 sensors.
Truck only has a pre cat sensor.. And almost 100% sure it's an aftermarket cat. So I'm guessing it probably has a plenum problem. I'm going to look at intake later today. Truck has duals y'd off of the cat. Don't think that's stock.. And cat has a raspy/rattly noise to it. Don't know if its a leak or the clogged noise you were talking about. Also going to try removing pre 02 sensor to see if I have any improvement
on
Update.. I'm pretty sure it's not a clogged cat.. Threw it in 1st on the column and it went all the way up to 4k rpms with no problem at all shifted into second and same thing but when it's in drive it won't go past 2.5k rpms.. Maybe something in trans? PO said he replaced the trans wondering if e put I a junkyard one
on
Might need to check TV cable adjustment:
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
