Still have shift issues
#21
The more load on the motor and depending on how bad the cat is clogged, it can do just that. I doubt it's the tranny . And please add ALL the info about your truck to your sig AND profile. This way people don't have to read back to your first post and/or ,ask/answer questions that don't apply to your vehicle. Thanks
#22
Yeah I took out the o2 sensor pre cat it got a little louder but still acted exactly the same.. And tv cable seems to be adjusted properly. Had someone press has to floor and tv cable on the trans moved at the same time he was hitting the pedal.. Is it attached Inside the transmission?? Maybe it's unhooked somehow inside..
#24
The other end of the TV cable is right on the driver side of the tranny, has a spring at that end. Here is a thread that has info about adjusting it to stock. A Haynes manual is also good for your 95. https://dodgeforum.com/forum/2nd-gen...-in-trans.html
#25
#27
Have you checked the cat yet though? Need to make sure...
Might need to check TV cable adjustment:
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
