9.25 Gear install ?
It isn't $100 of tools if you know where to shop and spend your money wisely. I've got everything I need to do up to a Dana 70 and have less than $500 into all the special tools needed. Doing it by feel is crap!! Your calibrated right had ain't that good. But knock yourself out and do it by feel.
I tried to use a flathead for the side adjusters and it just didn't cut it so I grabbed a piece of 4' rebar and a couple scraps of steel and 5 minutes later I had a handy tool to do the job.
I was going to rent a dial indicator but my neighbor said it was a waste of time(GM Master Tech that works on all the Corvettes at the local dealer.). So we just set it up by his feel and with gear grease. Have 20k on my gears with light towing around 4K and no problems yet.
Rectangle on the end was
1 3/8"
3/4"
1 3/8"
3/4"
