Skyjacker 501 kit install questions
  #101
Old 10-12-2013, 01:19 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
To cure your hiccup that tre goes in from the bottom of the new pitman arm not the top, just turn it over.
  #102
Old 10-12-2013, 04:18 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Looks good. I would recommend removing those stickers on the control arms for two reasons:
1. They will fade to yellow
2. They trap moisture and cause the arms to rust. I spent a good while filing off the rust and re-painting mine this summer.
  #103
Old 10-12-2013, 05:06 PM
InfO's Avatar
InfO
InfO is offline
YES. Definitely not enjoying them. I will scrub them off.
Here is a new picture of the project:
I didn't put the sway bar on. I want to order some new end links as mine are looking in ****e condition.
I am going to go through the instructions line by line, highlight anything I left out, and go in and finish up some stuff on it tomorrow. I need to run a brake line from the front to the rear, a few brackets have to be dealt with. Stuff like that. But yeah, pretty darn stoked! It's at the 90% solution!
InfO.
  #104
Old 10-13-2013, 11:00 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Great progress!
I also recommend painting those stabilizers again as the factory paint is very poor. They will rust even in just a couple years or sooner if you live in the snow belt.
Also saw your pic of end links earlier and they aren't the correct ones. Did you mean to fab a different set-up or get correct "L" shaped links?
  #105
Old 10-13-2013, 01:10 PM
merc225hp's Avatar
merc225hp
Looking good Bud! Nice work.
Oh yea Have a Good Turkey day over there eh.
  #106
Old 10-13-2013, 01:28 PM
InfO's Avatar
InfO
InfO is offline
Great progress!
Took me a second to track what you meant, but yeah - I meant for a different set. Was a bit miffed when it clicked - I think that is for the 2WD application? I will pick up some MOOG ones on Tuesday.
InfO.
  #107
Old 10-13-2013, 03:35 PM
InfO's Avatar
InfO
InfO is offline
You too, Merc! Hope you're having a good one? GF's sister decided last minute she wasn't bringing up her turkey. We had to go on a hunt this morning.
  #108
Old 10-13-2013, 03:56 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
  #109
Old 10-14-2013, 09:46 AM
InfO's Avatar
InfO
InfO is offline
Are the Moog end links not worth while? Will they not last? I was looking at these:
Moog K7280 Sway Bar Link Kit : Amazon.com : Automotive Moog K7280 Sway Bar Link Kit : Amazon.com : Automotive
Anyone want to chime in? I'd like to order these and the cam bolts today so I can get them by mid-week. Also, the remainder of the bolts on the control arms - should I order the specific ones that were in there before? I picked up some bolts, washers, nuts from Home Hardware, but they were SAE measurements and while I am sure are very close, might not be exactly the size I needed. They are also only grade 5 bolts.
  #110
Old 10-14-2013, 10:09 AM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
i have those links on my truck. v10 coils up front, and theyve been on there for over 3 years.
Quick Reply: Skyjacker 501 kit install questions
