Help
Help
98 dodge ram 1500 sport 360. Suddenly started chugging on the highway.rolled into town with little oil left and filled her back up and viola.
It seem's to be running ok, aside from the normal sucking the intake does (replaced IAC, but havent gotten to plenum yet... it's an idle leak, no difference cruising) it sounds like ( you can hear it in the video ) i lost compression via a piston ring, but unfortunately I have never been that far into to this size engine before and couldn't be certain without ripping it apart, which I just do not have the tools to do... Every vehicle I buy get @#!$ed man... Every single one... I have no luck and I'm about to invest in a nice *** bicycle... it may not haul much, but it can go almost anywhere and only has tires to worry about.
Please help...
Please help...
So have you done a comp test to confirm the lost comp in whatever jug? If you do have a jug down below spec then its time for a rebuild or a used motor. Not worth messing around to try and make it run right on 7 jugs.
So do a dry/wet comp test and post back your findings.
Yea, read a how to... pretty simply stuff. I'm debating whether or not I want to do it, as I hadn't noticed before, the smoke is sweet... and the smoke get's worse with throttle... I'm 99% sure it's the head gasket. I'll get back to you guys.
