What would cause steering wheel shifter to move freely from gear to gear?
Old 10-10-2013, 09:44 PM
shep28's Avatar
shep28
shep28 is offline
Default What would cause steering wheel shifter to move freely from gear to gear?
I can move the shifter to any gear without any effort. Car drives fine other than that. The normal "pull the shift lever back and then move to the next gear procedure" is not needed. At WOT the engine movement alone can move the shifter out of gear.
What could this be? Linkage? How can I diagnose and fix it?
Old 10-11-2013, 12:46 AM
merc225hp's Avatar
merc225hp
merc225hp is offline
To me this sounds like the shift lever detent ball and it's spring is broken, these are found inside the trany. I could be way off on this more will chime in soon.
Old 10-11-2013, 09:54 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Isn't there a 'gate' somewhere on the column to prevent just such an occurrence?
Old 10-11-2013, 11:04 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
Yep, it may be time for a new column....salvage yard.
Old 10-11-2013, 12:23 PM
97r/tram's Avatar
97r/tram
97r/tram is offline
Youll need a set of torx keys with the safety/hole in the torx end to change your ignition switch. Just an FYI because ive been there.
Old 10-11-2013, 12:45 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
15 bucks from Oriellys, ive been there also
Quick Reply: What would cause steering wheel shifter to move freely from gear to gear?
