new to forum and have a new question
#21
#22
finally got my hughes kit ordered this mornin, only a few more thing left to grab >another question: im not planning on completly disconnecting my fuel rail, rather just remove injectors from i.m. & set aside (new o rings of course).. if i do things this way will i still have to do 'relieve fuel pressure procedure'?
#23
#25
#26
cool i actually just had to grab a set of them when i did my radiator (didnt know what size so i got the pack lol).. anywhere i need to 'release pressure' from before i undo the quick connect? >my concern with leaving the injectors in manifold is i dont want to risk any damage to em while im scrubbing the i.m. clean.. (thinkin ill scrub all that carbon with diesel or something likewise)
#28
You can also pull the fuel pump relay and try starting the motor, this will release fuel psi as well, should be one of your first steps before starting this job. Leave the injectors in the im as posted, once the im is off remove the injectors, replace the o-rings, change the little filters in the top of the injectors. The best way to clean the im is take it to a shop that has a hot tank for cleaning parts.
#29
hey guys! finally got all my parts together for hughes plenum repair, just waiting out this crazy weather (no heated garage).. driving truck as little as i can but im starting to wonder if i dont have another problem also (trying to cover all bases) so im starting to suspect my timing chain also, was wondering if theres a way to check if its going bad (cant really hear over exhaust lol) without tearing into it & looking for slack? -figure if i need to put in new timing chain then doin it during plenum job would be perfect time ;-)
#30
