new to forum and have a new question
#53
#54
#55
On the crankshaft?
I use air tools, so, a lot less of an issue for me....
You could drop the starter motor, and use a pry bar on the flywheel teeth to prevent the motor from turning..... Or, if the pulley is still on the balancer, use a strap wrench around that. Don't put anything around the balancer though.
#57
advice
well i got her down to water pump & timing cover but when i took it off the 'u shaped gasket' around bottom of timing cover & oil pan it came off with the timing cover (tried to be careful). it didnt 'damage' peice that came off so can i still just RTV that spot a lil extra when replacing? >REALLY dont want to have to drop oil pan & fresh royal purple oil lol >tried to add pics but cant figure it out
#60
