check engine light/no codes
The check engine light came on while driving into head wind. when I got to my destination I did the key 3 times and it came up p done. The light stayed on so stopped and used the parts sore code reader and it came up with no dtc code stored in computer at this time. So I erased the light. Are there some codes that require a more sophisticated reader? I know my plenum leak is getting worse, one quart in 1660 miles. Doing the plate fix next week.
No codes again
Happened again today on the way after work. CEL came on, but there were no power train codes or freeze frame data. Did the key trick and just got p done. Borrowed cheap code reader at parts store and got no codes, but the the light is still on. Leaving it on until finding a better scan tool to see what's up.
Anybody have a CEL light with no codes?
Trending Topics
Not sure if the systems are the same but Harleys have current codes and historic codes. When you plug in to the digital tech(dealer only software) there are two different categories. If what is setting off the code is temporary it could fall under a historic code and is why the code reader doesn't show anything because it searches for current codes. Like i said not sure if they are the same systems but its a long shot theory.
CEL is still coming on at random. I've used three different scan tools, a couple were capable of reading live data and no codes were present. Last night I pulled the injector harness off #4 to force a CEL, which it did. I did get a code for injector circuit, so at least I know the PCM will detect an actual problem. But it's coming on every few hundred miles recently, with no codes.
As far as driveability, it does seem to be more nimble after I reset the PCM, but it could be my imagination.
Anyone have a similar issue? It comes on while accelerating to highway speed. Twice on the same exit, months apart.
