2001 ram 1500 transmission/ pump problem
Old 02-20-2014, 02:31 PM
Snuffy Smith's Avatar
Snuffy Smith
Snuffy Smith is offline
Question 2001 ram 1500 transmission/ pump problem
2001 ram 1500, 5.9. with 112,000 miles. recently changer governor switch & other sensor in trans. solved shifting problem until yesterday, heard noise like a power steering pump low on fluid, then all of a sudden it was like I shifted to neutral. coasted to stop, found nothing loose, when start back up it would make noise & pull forward 100-200 fy then do same thing, everytime I cut off motor & wait a few minutes it will make pump sound noise & pull forward or backward short distance. is this my pump? and is this an easy fix like the governor sensor? any help truly appreciated & needed...
Old 02-20-2014, 02:43 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Check fluid level, and see what it looks like. If it is a pump failure, it's rebuild time. Not an easy fix....
Old 02-20-2014, 03:59 PM
Snuffy Smith
Unhappy
fluid looks new, only 4 months since changed governor sensor & other sensor & filter with new fluid. thanks... now to find a shop to do it...........
Quick Reply: 2001 ram 1500 transmission/ pump problem
