2000 dodge ram 1500 5.2 ext cab 4x4 5 speed, it doesn't have 2nd gear, runs and drives just no 2nd, what other dodge vehicles can I pull a tranny out of? I've heard you can pull out of a dakota with the same engine? Is that true? If so, what all with I need from the dakota? If there is another way to fix this please tell me thanks so much!!!
Any Ram/Dakota NV3500 from a 4x4 should work. Just need the trans, and it should bolt right in. May wanna change clutch, pressure plate, and throw-out bearing while you are right there though.
