Diagnosing a problem.
Old 04-19-2014, 07:52 PM
RedTruckDaddy13's Avatar
RedTruckDaddy13
RedTruckDaddy13 is offline
Talking Diagnosing a problem.
Hey guys! Sorry I have been gone so long. I have been so busy with work.
In the last month my truck has been done. I have been told its transmission but I want other peoples input. First off, while driving I get to about 35-40MPH and I whines out. I let out of the gas for two seconds and I get back in it and It shifts into second and then it shifts back to first, finally it goes back to second and everything is fine.
Then I started having problems with my ignition switch. It won't go into park, it will only start in neutral. Again I have been told transmission but I am asking for others input. I am getting ready to go to school to become a Automotive Tech and then my transmissions classes. So I am getting there understanding cars. I know a good amount but I am getting there.
Thanks!
Old 04-19-2014, 08:00 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
h3lzsn1p3r is offline
Thanks!
if it will not start in park it is the neutral safety switch.
you may be looking at a solenoid in the trans going
Old 04-19-2014, 09:15 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
If you can't get it into park it could be a few things. Like h3lzsn1p3r said it could be your neutral safety switch or it could be that the linkage is out of adjustment. There is a way to adjust the linkage and it explains it in the FSM.
The not shifting could be the valve body, governor or a solenoid going or gone bad.
Quick Reply: Diagnosing a problem.
