Project time... Various questions.
Old 05-04-2014, 03:58 PM
xplorer82's Avatar
xplorer82
xplorer82 is offline
awesome. makes me feel a little better. Didn't do much for the engine today.. Pops came over and we knocked out the heater core. might mess with the engine a little tonight. we'll see.
I opened up the double roller box and noticed there is 2 "0"'s on the crank gear.
Which one am I lining up with the cam gear mark? The Keyway "0" or the other "0"
  #22
Old 05-04-2014, 04:11 PM
Twmays's Avatar
Twmays
Twmays is offline
The "other" 0, like in the second picture.
Again though, the key ways will guide you. Just don't just the "A" or "R" (which I'm assuming mean advance and retard, respectively).
Check your documentation to make sure which one keeps your timing stock.
  #23
Old 05-04-2014, 04:42 PM
xplorer82's Avatar
xplorer82
Originally Posted by Twmays
When I did mine, I turned the crank (with chain still on it, turning the cam at the same time) until the timing mark on the balancer lined up with the 0 mark on the block. Took the cover off, and the timing marks were out of line as were the key ways.
Studied it, read up on it, got more confused, and finally thought "well, if it ran before, as long as those key ways are there I can't really screw this up, can I?" I made sure NOTHING MOVED and got the new gears and chain lined up and bolted on and prayed.
Fired up just fine.
I honestly think that with the key ways on both the crank and the cam, the only way to mess it up is by turning one without turning the other.
So don't over think it, just be careful not to move anything and you'll be fine. After all, your existing chain is shot. You'll enjoy the improvement in your engine with a new chain.
(Although maybe I just got lucky?)
just seen this one till now...
I didn't check the marks on the balancer before removing it and the timing cover.. plus it was all nasty and covered so I just planned on doing the "rotor button facing the #1 plug location on the Cap". But I'm just going to line up the marks on the gears now.
You said your marks didn't line up after setting the balancer at "0"... Did you leave it like that, or did you line the marks up before you removed the chain and gears? just wondering.
I have not broke the cam gear bolt loose yet, probably wait till tomorrow. not feeling too ambitious tonight after bending like a pretzel to install the heater core. This dash didn't give me much play like my 99 did. And don't get me started on the cheap *** plastic dash, grrrrr... I "HAD" a nice dash
thanks again guys for not giving up on me yet, with the questions and all. I do have the FSM and Haynes and I have done my reading, but getting pretty confusing at times, one says this, other says that (some of which is pretty detailed) but then I hear its simple and im like...... mmmk..
i'm going to try and use the "KISS" method from here on out..
  #24
Old 05-04-2014, 04:43 PM
xplorer82's Avatar
xplorer82
no paperwork in the box to check
  #25
Old 05-04-2014, 05:07 PM
Twmays's Avatar
Twmays
Twmays is offline
I really just lined up the key ways. I didn't move a thing once I got the cover off. If it was in time before, and the new key ways line up just like the old key ways, then it'll be in time after.
You can line up the marks once the cover is off, sure, as long as you leave the chain on. Once you take the chain off, MOVE NOTHING.
I'm thinking the A, 0, and R are for "Advance 4 degrees," " 0 degrees", and "Retard 4 degrees," since that's what most of those multiple key way gears are. Mine had different shapes on the key way tops (flat, curved, and pointy) which was way more complicated if you ask me.
Go with 0.
  #26
Old 05-04-2014, 05:10 PM
Twmays's Avatar
Twmays
Twmays is offline
Oh yeah, I'm also rocking the 5.2, and I think our balancers are different- you might not even have a timing mark on your balancer for all I know.
Either way, trust the key ways.
  #27
Old 05-04-2014, 05:22 PM
xplorer82's Avatar
xplorer82
cool. thanks. I'm feeling more confident. Going to go out and line them up, just to have them lined up and i'll tackle the removal/installation tomorrow.
Thanks again.
  #28
Old 05-05-2014, 12:43 PM
xplorer82's Avatar
xplorer82
Ok, kind of scared now...
I lined up the dots, marked the chain and gear with paint.. I looked at the rotor button and it wasn't facing the #1 plug location for the dist. cap so I started to turn the crank to try and find TDC on #1....
I have been turning it now for quite awhile, gave up on trying to find the #1 TDC and just want to line my marks back up on the chain and gear, but they will not line back up. like I said, I have been turning for awhile now...
did I F myself or do I just need to keep turning. I did notice while I was turning the crank it would kind of "bounce back" after I let off my pressure. Not sure if the cam "bounced back" with it...
I'm getting scared now. I need my truck, like 3 days ago
  #29
Old 05-05-2014, 01:05 PM
xplorer82's Avatar
xplorer82
abort crash course...... got them lined back up, shhhhew....
but, my rotor button looks like it is a little off from where it was when I started turning the crank...
could that be from the "bounce back" cause my dumbass didn't take the plugs out before turning the crank and was building pressure?
should I leave it be, any options if not?
  #30
Old 05-05-2014, 02:17 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
If the marks on the timing gears line up properly, you are golden. With both dots lined up at 12 (crank) and 6 (cam) cylinder 6 is actually in firing position.
Quick Reply: Project time... Various questions.
