Band Anchor Found in Trans Pan?
#21
#22
#23
Well I just dropped the pan and the Valve Body. Noticed the rear band was worn right down. My adjustment was to the end of the bolt. I also noticed on the adjustment part the spring that goes up in the valve body is broken. I knew I had an issue when I dropped the pan I can smell the burnt fluid. Time to find a Transmission Garage and price a rebuilt.$$$$$$$ Thanks for all the tips......
#24
#25
Well The Dodge is in the Garage Getting a Rebuild on the Transmission. The rear band was bad and the rear servo was broke. I'm having the whole transmission rebuilt. The total Cost is $1500.00 Will update when I get it back and test drive.
#26
Manifold Leak after transmission Replaced
Well I had the Transmission rebuilt. $1500.00 with a 1-yr Warranty. Then the garage calls me and says I have another issue. The truck Manifold gaskets are cracked and now my truck is loud? When the transmission was taken off the engine moved and seperated the manifold gasket alittle which makes its loud. Is this common when this service is done? Thanks Warren
#27
