Band Anchor Found in Trans Pan?
My Transmission is working perfect. No hard shifts. Fluid is great. I only have 95,000miles on it. I also serviced this 2 times since I owned it. Just it was never adjusted. I want to put the anchor back up in place and adjust the 1-2, 3-4 anchor bolts to 72 INCH pounds and turn back three times. It was the front band anchor. My shift from first to second I have to give it gas then let off to shift to second around 25-30mph's. My question is do I have to remove the Valve Body or can my hands fit up above it?
2001 2500 Dodge Ram 5.9 Gas
I found an anchor in my pan too. While in there replaced the front band with a slip-in. 8000 miles and 6 months or so later, all is well. The anchor usually fallls out due to excessive front band material wear. Yes, drop the throttle body and plan on a new front band, since you are in there.
https://dodgeforum.com/forum/2nd-gen...trans-pan.html
Not hard. Remove filter, and the shift levers on drivers side of trans., a few screws holding it to the trans.,you can pull it out with the park rod attached.
Don't need any gaskets or seals, just a pan gasket when you put it back together. There is an O-ring for the shift lever you could replace just to be on the safe side.
Trending Topics
Well my son and I pulled the transmission cover, filter and a hell of a time to get the shift levers bolts off hard to reach. Any way we were able to replace the Anchor and adjust both bands and everything looked really clean and no wear marks. After adjustment and put back together with new fluid it works like it was new Shifts perfect... To bad all the trans services (Fluid Changes) I had they never did adjustments. Saved $550 that a garage wanted to do and he wanted to pull out the trans? Thanks for info
OH Dear, I have not used the truck very much since June but I'm now loosing Reverse. I check fluids and everything looks fine. Clean not burnt I checked the linkage and that's ok. What would cause this. I replaced the band anchor and did the adjustments per front and rear by the book. Help winter is on the way and I need to plow with this beast....
