Might be clutch pieces...... might be the clips that hold things in place. In either event, time for a rebuild back there. It will cause some strange noises...... depending on how bad it is.
I think you can get a generic rebuild kit for around 100 bucks. Basically, clutches, steels, clips. No bearings that I am aware of. I don't think you even need to removed the carrier to do it. Couple hours in your driveway, and you should be set.
ok guys this is what i found in my rear axle what is it and could this be causing a noise that sounds like a u joint flopping??? Sorry it took so long i'v been on the road.
Time to rebuild the rear clutch pack is coming apart as mine did
