Check and see that you are getting 12 volts at the coil while cranking.
If that's ok, hook one end of the test light to the positive battery terminal, and poke the other into the ground side of the coil connector. See if the light flashes.
Now that you have a PCM, you need to have it flashed to your vehicle vin #
Iv had to have new, and used ones flashed in the past. Call a dodge dealer and ask them.
Just a thought.
Hmmm. Good to see its all fixed up. Sucks that the newer pump caused all this trouble though.
I'm having troubles with my 2000 now... Lol, last time out, all good cold, and starts to bog once warm... Misfires through intake if pushed, then clears up ? Quick check plenum is o.k. Coil fine..... Maybe I'll need a pump soon too. I gotta connect a fuel test to it and drive around some.
