Transmission problems - DodgeForum.com
Old 07-15-2014, 02:34 PM
98dodge2500.'s Avatar
98dodge2500.
98dodge2500. is offline
Default Transmission problems
The past couple of times I've tried to drive my truck I start to give it gas and it starts to go but it barley moves and the rpms are at about 2500 and that's barely giving it any gas. Then when I started to drive, it dropped out of gear and into neutral. Then I had it going 45mph and it wouldn't shift into the last gear, the toms would just keep going up. What's the problem
Old 07-15-2014, 02:40 PM
HeyYou is offline
Super Moderator
Have you checked your fluid level?
Old 07-15-2014, 02:44 PM
98dodge2500.
Yes we replaced it and the filter and it's still the same.
Old 07-15-2014, 02:55 PM
HeyYou is offline
Super Moderator
Remember to check fluid level in neutral. Park will give you a false high reading.
Assuming you are talking about a 98..... On the drivers side of the trans, about halfway back, is an 8 pin connector. Unplug it. Take the truck for a ride. Bear in mind, you will have ZERO automatic function. If you don't tell it specifically to shift, it won't, and it will start off in whatever gear you happen to put it in. So, start out in first, and shift to second/third at appropriate times. You will not get TCC lockup, or O/D in this test, so, don't go far. If it all shifts nicely, when you tell it to, you have an electronic problem. If you still have issues, you can try adjusting the bands..... if that doesn't help.... rebuild time.
Related Topics
Thread
Forum
Replies
Last Post
john_2216
3rd Gen Ram Tech
6
11-09-2015 10:42 PM
drd5169
Dodge Caravan
7
10-25-2015 04:17 AM
donnyh13
2nd Gen Dakota
7
07-14-2015 07:34 PM
johncrawford1
Dodge/Ram Diesel
0
07-14-2015 11:08 AM
eagle101
2nd Gen Ram Tech
2
07-12-2015 11:43 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
