Trail Carnage.. help :\
Only shift solenoid is for O/D. First three gears are controlled by the governor pressure solenoid, and pressure sensor.
Try this: Disconnect the 8 pin connector on the drivers side of the trans, 'bout halfway back. Take the truck for a ride. You will have zero automatic function, so, start in first, and shift when it is appropriate. (both up, and down.) You won't have TCC, or O/D either...... If it shifts nice when you tell it to, then you have an electrical problem. If it doesn't, well... then you have some other problem.
Okay I have an update. I have 3rd and 4th now. I really dont know how or why but I do. I have another problem though. I think the tranny overheats. Was going down the road 10 min ago doin 55mpg going up a hill. Truck started going slower and slower and then I was stopped (still in drive). Let it cool down for 5 minutes and it took off again but a lot slower than normal. Get close to my place and I feel the truck starting to slow down again. Rolled in my driveway popped the hood and my rad is boiling. My motor isn't too hot. Normal temp Tranny fluid was boiling hot as well
EDIT: 20 min later and my rad is still sizzling :S I've been told my tranny cooler may be plugged on the outside but it's clean.
Engine temp gauge is good. Normal operating temp. Tranny temp light did not come. Tried the truck again 5 minutes ago when everything was cooled and it still has a hard time moving. Put it in gear and it takes almost everything the motor has to move. I'm starting to think maye the filter is plugged? I changed it last night but there was lot of debris in there
If you don't have luck with this change, you might try Auto-RX...
Again, adding stuff to your transmission fluid is generally not recommended, but my transmission's performance was driving me nuts so I was willing to gamble. So far, it seems to have been worth it. It won't work a miracle if you have a mechanical issue, but it might just help un-clog a dirty shift solenoid if that is your problem. If your alternative is a rebuild, it may be worth a shot. But do some reading on the product to decide if you want to try it.
Good luck. I hope you can figure it out.
