01 2wd 5.9 rough idle, free cam lope? - DodgeForum.com
Old 07-31-2014, 05:42 PM
JKresge's Avatar
JKresge
JKresge is offline
Default 01 2wd 5.9 rough idle, free cam lope?
That's what it reminds me off anyway, a lopey old cam.
It's worse when it's a cold start but it's always there to some extent.
Here's what I have done in the past month. Intake manifold was fixed 3 months ago.
-coil
-cap
-rotor
-PCM from Solo
-IAC
-TPS
-Crank Postion sensor
- Cam position sensor
- gutted stock cat
The rough idle started about 2 months ago. At that time I did the sparkplugs and it seemed to run better for about a week.
Then about a month ago the truck just died. It ended up being the PCM. When I finally got it fired back up there was a pretty severe lifter noise from the drivers side head close to the firewall. I ran some motor flush through it and changed the oil, added a can of Restore and let it sit. I had a feeling that the cat might be plugged so I didn't want to drive it until I changed it. I ordered a Flowmaster cat from an online place...3 weeks later I told him to cancel that order and I gutted the cat. I've been driving the truck all of this week and there's been no change in the idle quality.
I threw a set of 24lb Ford Mustang injectors on it thinking that maybe one of the stockers was dying since the truck has 160K on it.
There is an exhaust leak on the drivers side as well which I think is at the block/manifold connection. I have a set of gaskets that I'll be install this weekend.
Is it possible that I have a bad lifter that is slow to pump up and even once it's pumped up is still not all the way?
Oil pressure is at like 40psi at idle and 60 psi rolling down the highway.
Could the exhaust leak be the culprit?
Oxygen sensors? They're still the stock ones as far as I know.
any help, suggestions, offers to help push it off a cliff would be greatly appreciated.
Jeff
Old 07-31-2014, 06:06 PM
HeyYou is offline
Super Moderator
Does it do the rough idle thing as soon as you start it up? Or after it has been running a couple minutes?
What's fuel pressure look like?
Compression test?
How did the plugs look?
Old 07-31-2014, 09:05 PM
JKresge's Avatar
JKresge
JKresge is offline
Compression test?
Starts immediately at startup, actually settles down some after a few minutes.
Fuel pressure is at 45psi
Plugs are really clean. Just checked them again this week since I've been driving it to work (30miles one way).
Old 07-31-2014, 10:12 PM
HeyYou is offline
Super Moderator
Fuel pressure is a touch low, but, shouldn't be enough to make a difference..... however, the fact that it gets better after a few minutes..... that is when the PCM starts paying attention to the O2 sensor.... so, maybe a lean burn miss?
Were all your plugs a nice uniform tan color? (they should be...)
Old 08-01-2014, 08:54 AM
JKresge's Avatar
JKresge
JKresge is offline
Yep, all plugs were a real nice tan color. That's what makes this so frustrating, other than pouring money into the truck. All the logical things that I can think of that would cause this are not the fixes.
Old 08-01-2014, 10:15 AM
HeyYou is offline
Super Moderator
Maybe it's time for a compression test.... (dry/then wet.)
Old 08-01-2014, 11:11 AM
Ram Driver's Avatar
Ram Driver
Ram Driver is offline
If your 02 sensors are original with 160,000 miles on them, then there way past due for needing to be replaced. The 02 sensors should be replaced every 70,000 - 80,000 miles.
Old 08-03-2014, 11:43 AM
JKresge's Avatar
JKresge
JKresge is offline
Tried to do a compression test yesterday while I was installing exhaust manifold gaskets but my test guage is not holding the pressure.
Only did the drivers side of the engine dry since it was a pain to try to crank it and watch the gauge.
1- 120psi
3- 100psi
5- 130psi
7- 150psi
Naturally they're just what I could see the needle on the gauge bouncing to on the compression stroke.
I think since the lifters are about $100 a set I might order a set and see if they fix the issue since the noise I've heard since I bought the truck was not the manifolds leaking as I found out yesterday. What a waste of a day even though I could see that the manifolds were leaking some.
Old 08-03-2014, 12:22 PM
HeyYou is offline
Super Moderator
Hhhhmmm..... Think I would pick up a new gauge, and rerun that test. By those numbers, you are out of spec. (all cylinder over 100 PSI, and within about 10% highest to lowest.)
Related Topics
Thread
Forum
Replies
Last Post
Miketech137
Dodge Caravan
5
10-20-2015 07:27 PM
RPB_IA
2nd Gen Neon
8
09-06-2015 05:31 PM
MoparNut87
1st Gen Durango
9
07-30-2015 05:30 PM
JoshuaYsassi
2nd Gen Ram Tech
63
07-24-2015 01:14 AM
pilotforlife
Dodge Stratus
3
07-08-2015 11:35 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
