Pushrod Question
Old 08-03-2014, 01:57 PM
renardk764's Avatar
renardk764
renardk764 is offline
Default Pushrod Question
Might be a silly question and i may be one thinking it, but I have adjustable rockers and a custom grind cam. Do I need to measure the pushrod and order custom length replacements?
Thanks!
Ken
Old 08-03-2014, 02:37 PM
Ram Driver's Avatar
Ram Driver
Ram Driver is offline
As long as you have enough adjustment on the rocker arms to properly adjust the pushrods, then you don`t need custom length replacements.
Old 08-03-2014, 04:45 PM
renardk764's Avatar
renardk764
Got it. Thanks!
Old 08-04-2014, 08:14 PM
Adobedude's Avatar
Adobedude
Adobedude is offline
What...? That doesn't make any sense, and from what I can make of it is wrong.
You use an adj push rod to determine the correct valve train geometry, or the sweep of the rocker arm roller over the top of the valve stem, you want it centered. Once the correct length PRs are installed you adjust the valve lash for the proper preload.
If the push rods are not the right length when you adjust the lifter preload your rocker arm geometry might be way off.
Old 08-04-2014, 10:07 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
What he said.
Old 08-05-2014, 02:46 PM
renardk764's Avatar
renardk764
That makes sense. Knew I was out in left field. Thanks
Old 08-05-2014, 04:50 PM
Wildman4x4nut
I have the adjustable push rod for checking. PM me and maybe we can work something out where I would rent you the tool. You just give me a deposit and then I'd mail it to you. Once you're done with it just ship it back to me.
Now one of the push rod length checkers are only $15-20 so it might not be worth it. It's up to you.
Old 08-05-2014, 06:25 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Custom length is certainly optimal, however, unless you have shaved the deck of the block substancially and/or shaved the cylinder heads substancially, you will be fine with off the shelf hardened pushrods designed for your motor. For example, I'm building a 408 stroker with Edelbrock RPM heads and will use Edelbrock hardened pushrods with adjustable 1.6 ratio roller rockers.
Old 08-05-2014, 07:02 PM
Adobedude's Avatar
Adobedude
I think what you mean is you measure and order PRs closest to the right length, which is the way to do it, and that might what Ram Driver was saying too.
Old 08-06-2014, 05:57 PM
renardk764's Avatar
renardk764
New casting heads (EQ of course) and 390 stroker, zero decked with custom grind cam. Engine Specs are attached. I think I'll go ahead and go the custom route. Probably safer bet.
File Type: pdf
Quick Reply: Pushrod Question
