Lost T/C Lockup for the second time *Help*
ah yes... i had the same thing happen with mine..
What fixed it for me (and from what i am told there is a TSB for it) the orifice filter in the overdrive piston housing worked loose and fell out leaving all the pressure to just bleed out and lead to no overdrive. With doing 2000 RPMs @55 mph you don't have overdrive. You should have about 2k RPMs at 70MPH.
