what the he*# is this?
#21
Ok, here's what I gathered. The trans temp pin on the pcm showed 1933 ohms, with a ambient temp of 80 degrees. I still have no trans codes, nothing odd other than the overdrive. Unfortunately my scanner doesn't show live data and I can't see a way to backprobe the connector so I can hook up a voltmeter at speed and see if the pcm is doing its job. Just for giggles I checked all the fuses by the driver door in the dash and in the pdc. All checked out good. I also swapped the trans relay with another relay again, just to see what would happen.....nothing did.
#22
The part that makes the wires go in an angle is a cover. there should be four prongs that release it... after that you should be able to probe it.
#24
#25
#26
It pays attention to throttle position/engine load as well. If you can cruise at 60, steady state, and it doesn't drop to zero, PCM is either not requesting O/D, for whatever reason, or, there is an internal fault in the PCM. (bad circuit) If it is requesting it, and not getting it, it should set a code...... since there are no codes, that would imply that it simply isn't requesting it. Next trick is, WHY isn't it requesting it.......
#27
So if the pcm isn't requesting overdrive, then I could replace the pcm and theoretically fix the problem right? However, that's $300 plus I don't have at this moment. This may be a dumb question, but, is there a way I can manually ground the wire from the pcm while at speed. Hook up a switch or a button or something?
#28
#30
