what the he*# is this?
Old 08-19-2014, 04:14 PM
98beater's Avatar
98beater
98beater is offline
Sweetness. Thanks for your help guys. Ill let you know how it works out tomorrow.
  #32
Old 08-20-2014, 12:27 PM
98beater's Avatar
98beater
98beater is offline
I hooked up a ground to the 3-4 shift solenoid wire. As soon as I touched the wires I got p0753 shift solenoid a, and the truck went into limp mode. Cleared the code, shifted fine again and code came back as soon as I touched the wires again. I just changed the solenoids in the trans. I don't know whats going on now.
  #33
Old 08-20-2014, 01:01 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
When you ground the wire, the trans should shift into O/D, regardless what the PCM thinks. PCM is whining about not being able to control it.....
Begins to look like the solenoid is bad if it isn't. Just because it is 'new', does not imply that it is good.....
  #34
Old 08-21-2014, 09:19 PM
98beater's Avatar
98beater
98beater is offline
The od solenoid is the goofy looking two sided one that bolts into the side of the valve body right?
  #35
Old 08-22-2014, 10:06 AM
Yeah, one is the O/D solenoid, the other is the TCC solenoid. I think it is easiest to just replace them as a set.
  #36
Old 08-22-2014, 04:41 PM
98beater's Avatar
98beater
98beater is offline
This might be a dumb question, but do you know of a way to test those out of the truck, or is there a way?
  #37
Old 08-22-2014, 04:54 PM
Probably.... but, I don't know how... Simply applying voltage across the wires should trip the solenoid.....
  #38
Old 08-22-2014, 05:29 PM
98beater's Avatar
98beater
98beater is offline
That's what I was thinking. Time to experiment.
  #39
Old 08-22-2014, 07:31 PM
Old_School's Avatar
Old_School
Old_School is offline
Test the ohms coming off it. Put the positive lead on the center pin and then touch each of the outer pins with the negative lead... both should give you a reading of 25-40 ohms.
