Help indentifying a few hoses
Yep...looks like the fog light connector! which takes us back to the age-old question of where the wire harness connector is behind the dash for the fog light switch that is supposed to go next to the OD button on the dash? My '96 1500 has the two factory installed relays and fuse in the under hood drivers side fuse box, the wiring harness is all there to the front...tuck under the radiator, and presumably wired all the way back into the cab. Since fog lights were probably a dealer installed option in 1996...it is logical that somewhere behind the "blank" for the fog light switch next to the OD switch is a perfectly good factory connector...but I'll be darned if I can find it!
