No o.d.
No o.d.
I recently purchased a 2000 Dodge Ram 1500 Laramie from a private party. It test drove fine and it was from OK. so no rust and we bought it. NOW, I drove it 140 miles to get a trailer and all worked just fine. Coming home we had no overdrive. Changed fluid and filter. No bad smell and very few shavings. Took it to the dealer(not normal) and they wanted to tear it apart. NO. Pulled a trailer 30 from home OD works fine. Coming home no OD. Tranny shop said it runs and shifts too good to be major and indicated it was not getting signal to upshift into OD. I have changed the output speed sensor and plug along with the tranny control plug on top as they had bare wires. Still no OD. It has a 5.2 with I believe a 46rh-re Trans. 185000 miles Runs and shifts good. OH YES, it does not pull a tranny code either. Where do I go from here?
THANKS
THANKS
THANKS
THANKS
it's a 46RE.
Its either the PCM not commanding O/D, O/D solenoid, Transmission temp sensor giving false reading, or the O/D piston seals are going bad. When my O/D piston seals where going bad id have O/D sometimes and others not.
I would start with the easiest, test the PCM to see if its commanding O/D. To do this probe B21 (white plug) with a muti-meter. You should have 12+ volts while its in gear 1-3 and when the O/D off button is pressed.. once it commands 4th (O/D) the volts should drop to 0. If it does that then your PCM is good.
You can also test the transmission temp sensor by probing pin 1 of the same white connector. This one you wanna measure the ohms and a 70F you should see close to 1000 ohms
No od
Old school: I will start with the measurements. The tranny guy did say the red wire on the tranny control plug should have 12v and it does not.
Good place to start.
Hey You: Trailer was very light. & My fifth wheel doesn't see overdrive.
Thanks guys,
Time for some work in the morning.
Thanks guys,
Trending Topics
