which t cases will work
Old 08-28-2014, 04:23 PM
bbrideau's Avatar
bbrideau
bbrideau is offline
Default which t cases will work
Have NV3500 5 speed in my 99 ram. t case split and grenaded i think the stamp says 231 on the t case but before i drive 2 hours round trip i wanna make sure what im getting will work. Which t cases work with the NV3500?
231
241
any others or particularly any that are worth "upgrading" too?
Old 08-28-2014, 04:58 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
241D, or, 241HD would be a nice upgrade. I think there are some differences between t-case of manual, or auto trans..... also, difference in those behind the v-10, or diesel.... If you go with the 241, gonna have to do some creative stuff with driveshafts too... most any 231D will bolt right in, and hook right up. You want a t-case from a 98 or newer truck to match the shift pattern though.
Old 09-02-2014, 09:42 PM
bbrideau's Avatar
bbrideau
bbrideau is offline
so the 231 out of a dakota should work as well im guessing? how much of a difference would there be in driveshaft lengths if i swapped to the 241?
Old 09-03-2014, 08:58 AM
HeyYou is offline
Couple inches I think..... several folks have done that swap.
Also, if you are feeling froggy, the NV242 is a viable option as well. Also has a 'full-time' FWD option. (basically, AWD.)
Old 09-21-2014, 11:55 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
What is the output spline count for the nv3500? I think I confused with nv4500, which will impact transfer case.
Edit: answer found here https://dodgeforum.com/forum/2nd-gen...ml#post3197043
Specifically 98 1500 318 with nv3500 trans and np231. Np231 behind auto and manual are NOT direct swaps.
Old 09-29-2014, 03:19 PM
BackwoodsRam's Avatar
BackwoodsRam
BackwoodsRam is offline
at most all you should have to do to make the tcase work is swap the input planetary gear set from your old tcase. they are pretty tough so it should of survived the grenading. its not hard, just time consuming. that way if there are different spline counts the problem should be solved.
Quick Reply: which t cases will work
