Hughes Airgap causing issues
#31
#32
I have a Denso O2 sensor on the way. $25 from Rockauto, local parts store wanted $65 for same brand.
Unfortunately I did not get pics. I was in a bit of a time crunch, and rushing caused about 95% of the issues I ran into. I know, do it right or do it twice.
Whats wrong with using hose clamps? I could not for the life of me get that stiff line on there. I bought a high quality fuel injection rated hose and clamped it on, have not had a problem since.
#33
#34
#35
#36
#37
#38
Well gents, the issue returned after the new O2 sensor. It worked fine for awhile after the sensor, but had an episode this morning on the way to work.
I really don't think its a vacuum leak. A vacuum leak would consistently cause a similar issue, at least the way i think about it. I think there is a failing sensor somewhere that works when it wants to that is causing me grief. The TPS comes to mind. Also wondering about the sensor behind the intake by the distributor cap? What it is and what it does? Wondering if I damaged it during my work. I also replaced only the front O2 sensor, I know it was recommended that I do both but I am running out of funds to replace parts that don't have a chance of fixing the issue.
#39
Sensor next to distributor is the oil pressure sensor. It won't have any direct affect on how the engine runs.
Think I would go exploring for vacuum leaks again..... especially around the throttle body, and the intake to block surfaces. I would also disable PCV, plug all the holes, pull of the oil fill cap, and see if you are getting a breeze, or if it is still sucking. (should be a breeze... if its sucking, then the intake isn't sealed to the head, and is sucking air from the crankcase.)
If all that check out..... make sure the little vacuum line for the map sensor is intact, and not plugging up.
Check TPS voltage at idle while the problem is present. Also check voltage with the throttle slightly cracked.
#40
