Tow Pig friendly motor mods
I'm about to buy a long block 360 for my 01 dodge QC 4wd. This truck will mostly be used for a tow pig. Pulling fishing boats, UTV and in the near future a camper. This is the second 1/2ton 2nd gen rams I've owned but never done much aftermarket mods to them. Now that I'm starting with a fresh 360 was looking to do some mild mods to it. Looking for some suggestion on headers, high flow cats and exhaust setup that wont kill the low rpm torque need for hill in the northern part of the state. Wondering which air intake would work better for my needs a F1,M1 or a mod keg. Also thinking about installing some 1.7 H&S roller rockers before I install this new long block but unsure about that. Hoping someone here can sell me on them. I thought about a small cam upgrade but I'm unsure about all the tune stuff still and everything I've read says for the max results must use a tune. The transmission is getting rebuild with some upgrades when the motor gets pulled.
skip the hs rockers. Get a torque cam, buy a sct tuner. and put some shorties on it. get a 50mm throttle body and keep the stock intake and you will have a very low end torquey engine. for right around a thousand bucks. same price as rockers exhuast and maybe an intake. but you will get much more out of it.
you have a 01 so you have a much better y pipe then the early years. I would just start with what i have listed above. exhaust mods for performance are overrated. these engines are not fire breathing monsters limited by exhuast restrictions from the factory.
Trending Topics
Shorties may not help as much as a set of long tubes.... and an H pipe, but, I think Pacesetter makes the only set of reasonably priced longtubes, and the tube size is a bit large for a torque motor, still, better than the stock manifolds, or shorties. Would require a bit of work for a Y pipe though. (or, you can spend the 180 bucks or so on the pacesetter y-pipe.....) Will also need to add a cat to that if you have emission testing where you are.
Go for a good "RV" cam. Something designed for Idle, to wherever. (some go to 4500, others up to 5000, anything beyond that, and you will be losing bottom end, to gain a bit of top end.) Having a chat with someone like comp cams, telling them what you want to do, they can give a good recommendation. Keep in mind, you may not valve springs as well.... Depending on the cam.
If you can spring it, going with some stock ratio roller rockers, or, let the folks you are getting your cam from know that you want to run the 1.7 ratio, will also free up a few ponies, and give you a stronger, more accurate, valve train.
Just adding the 1.7 ratio rockers to a stock motor is generally good for 10 HP/TQ.
