2002 5.9l 360 evap
Old 09-16-2014, 09:34 PM
Cooper481's Avatar
Cooper481
Cooper481 is offline
Exclamation 2002 5.9l 360 evap
I've got a 2002 ram 2500 with the 5.9 gas and I have an evap code coming up. Any thoughts on what it could be. I've checked over everything and found the air box wasn't mounted right, so I fixed it, and found a evap purge line was cracked so I replaced it. I reset the computer multiple times, but the light keeps coming back on after a day or so. The truck runs just fine, but the check engine light is getting annoying.
Old 09-17-2014, 09:17 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Welcome to DF.
Telling us just what code you are getting would help......
Old 09-17-2014, 06:05 PM
Cooper481's Avatar
Cooper481
Evap leak detected. I've checked everything and nothing seems to be leaking or damaged or loose
Old 09-17-2014, 06:28 PM
982500's Avatar
982500
982500 is offline
I was having the same issue, found one of the vacuum lines on the passenger side up at the firewall broken. Look really close at all of the vac lines. I also had the same symptoms.
Old 09-18-2014, 06:20 PM
Cooper481's Avatar
Cooper481
I will try that. Thanks
Old 09-18-2014, 09:35 PM
Blitzkrieg's Avatar
Blitzkrieg
Blitzkrieg is offline
And what did you find? I am having similar issues , possibly a plenum issue also.
Old 09-19-2014, 07:45 AM
Cooper481's Avatar
Cooper481
I haven't been able to find any cracks or broken hoses. The only thing I've found is the small line on the top of the charcoal canister comes off pretty easy. All the other lines like it take some doings to get the lines off.
Old 09-19-2014, 11:04 AM
HeyYou is offline
How's your gas cap? Even that can set an evap code.
Quick Reply: 2002 5.9l 360 evap
