front axle not centered?
#31
Spot on HB.
Juvenator -- what are you doing to this poor ORE???? You should have like 1 or 2 alignment sheets (before/after). Are you will to share them? While the sway bar links can help identify an issue, at the same time don't make them a critical part of assessing the system altogether. You have a tape measure where you can do some basic checks.
For example for the rear, measure outside of frame to center pin. Use some straight edges. Same for both sides?
For the front, you can look from the front and at least see if the bump stops are inline (generally) with the pads on the axle. Measure similarly with the frame. This gives you a ball park. I wouldn't go by the tires as an absolute.
Look at your lower control arms at the axle. Are the bolts in the same location in the slot for both sides?
These are some starter things for you to check out on your own.
#32
#33
Okay, so I went to another shop and told them what was going on. I showed them the paperwork that P&M auto (shop that installed track bar) gave me. In the paperwork it clearly states that they purposely put the truck OUT OF ALIGNMENT to center the axle. The guys at the other shop said they should never purposely send a vehicle off being out of alignment knowing it can pull to one side (also stated in paperwork). He said I should go back and demand that the truck be put back in alignment. Soooooooo I went on back to P&M and told them what the other shop said. They told me that they will put it back in spec but that the axle will look off center again. It WILL be in spec, and drive down the road straight and not cause any strange wear on tires, BUT won't be centered. To do that they wanted to charge me $400!!! After some choice words they agreed to do it how they had it the first time for free. Again. When I asked why the axle won't be centered even after the instilation of an adjustable track bar they went on to tell me that "that's just how these trucks are, they all ride dog-legged" "go look at another dodge truck, especially if it's lifted, and it will be dog-legged". I don't understand, is this true??? I thought that was the purpose of an adjustable track bar, to re-center the axle. I know the front axle is wider than the rear, but I don't see why it wouldn't be centered front and back. As of now I'm taking the truck in on Friday to be put into spec. After I get it back, what do I do?
#35
The bottom caps aren't nearly as important as the tops. You have nothing to worry about there. The spring perches are what actually locate the rear axle.
The first shop is feeding you a line of crap. Had you just adjusted your track bar, and re-centered the steering yourself, you would have saved yourself a lot of headache.
#36
#37
#38
#39
I still have no clue how the idiots at P&M Automotive couldn't figure this out. And can't belive I was dumb enough to not just do it myself. Literally loosened 2 nuts and 2 bolts. Turned some stuff by hand (don't know why those guys f'd up my bars finish) and boom! Done! Check it out
Nut on one side of the track bar
Other side
Drag link bolts
End links
Tires
Other side
Drag link bolts
End links
Tires
#40
