Weird Vibration in 1996 Ram 2500
Hi I have a 1996 Dodge ram 2500 v10 5 speed manual. Lately for like the past 5 month at 38-45 mph there is a noticeable but not over cumbering vibration coming from the back area of the truck at least that s where I think it is. The reason I think it is coming from there is because the steering wheel doesn't have a vibration in it, nor does the truck ill handle at all at those speeds. the vibration started after I replaced a worn out u join in the rear driveshaft that connects to the rear end. In the past 3 weeks I have replaced the tires and wheels. Tires I went from 285/75r16 mud terrain tire to a factory sized 245/75r16 highway tire and that helped a little bit. shortly after I replaced the steel wheels that I have had on there for 10 years with a set of new worx triads factory sized
Pleaase help!!!!!
Pleaase help!!!!!
Trending Topics
I have a 1999 2500 gas-auto Ram truck
been fitting the same issue
have ( all was needed) rebuilt rear end, balanced drive shafts (front and rear)
replace shocks and had tires balanced
still have a little shack that feels like it’s right under the front seats.
been led to believe it could be in the trans now.
looking for any info on this
thanks Robert
thanks Robert
