Wheel seal help
Wheel seal help
Well I seen this morning that both of wheel seals on my front axle are leaking. Passenger side had a small puddle underneath it and was dripping, the driver side was soaked around the u joint and little up the axle. I'm gunna try and replace the wheel seals myself. I've done wheel seals on semis before but never on my truck. I'm going to looking around DF for more info on this topic. What I'm asking for is anyone know of any tips that can help me or any useful knowledge they've had in past experiences with these wheel seals?
see here.
http://www.pavementsucks.com/tech-article-3.html
http://www.pavementsucks.com/tech-article-5.html
i thought we had one in here, but i don't see it. the service manuals are here.
there's a lot of threads with good pics, but i guess they scattered back in history. you can search my old posts to find them.
https://dodgeforum.com/forum/2nd-gen...d-how-tos-143/
for the passenger side, you have to make or buy a seal puller, and seat it inside the cad. for the drivers side, you have to remove the differential and tap it in in the inside of the pumpkin. get good seals, National or Mopar or SKF because you don't want to ever do it again. while the diff case and tubes are empty, clean all the dirt, mud, rocks, sticks, and crap out of them. and lastly when reinserting the axle shafts, be very gentle and lift them up over the seal lips.
These seals are more of a pain than changing the ones on semis Lol. nahh there probably not that bad just time consuming, i too need to do mine, my passenger side is leaking but if im going to have the front end apart im going to do both sides and while im at it im going to get the outter axle tube seals to keep dirt water sand etc out of there when im off roading.
My feelings on this, too. Just be sure to keep the axle full of gear oil, so that you don't end up with issues due to lack of oil from the leak.
Trending Topics
