Wiring Blues
Wiring Blues
Alright, so I bought a new set of off road lights, as I mounted the old ones on the bottom of the bumper(in sig) and first mud run they were completely destroyed, so I redid most of the wiring as some of the mishaps I had initially wiring them in (lack of fuses and some melted wires) Anyways, I have the wiring as follows:
Lights grounded together and connected to Pin 87 on relay
Pin 85 is grounded to frame (using battery ground)
Pin 30 is linked with a 20A fuse to the battery
Pin 86 goes to single pole 40 Amp switch and other line goes to battery with another 20 Amp fuse at battery
Here's my issue, I have power to the relay and to the switch when on, but nothing is going to the lights. Google does not help with this issue, so here I am. I am in no way or form an expert with wiring and really want/ need these lights to be working for the highway driving up here as the stock headlights suck.
Lights are 55W each and they are both mounted on top of the bumper, in front of the grille.
I should clarify that the lights are grounded on the frame and then the + side goes to pin #87. I get power to the switch when I turn it on and there is power at the relay all the time. I'm completely stumped as to why neither relay works. I will double check when it's lighter and warmer out and maybe move the grounds around. Pin #85 is using the same ground my battery uses, is what I meant as well
When I did mine, I downloaded relay instructions from the net and studied it a while because I have zero electrical experience. Turns out, I was able to effectively wire up not one but two sets of lights: one set of driving lights up front and a set of backup lights in the rear under the bumper. They have worked now for over three years without issue. Both have lighted switches too which made for another wrinkle. Maybe just start over with a new schematic and wires? I remember using existing grounds near the battery. Could be something isn't crimped just right (if you're not soldering) or something isn't grounded.
Some ramblings from an old guy.
Many lamps do not ground properly with the mounting. Often, it's better to add a second ground wire right to the lamp connection inside the lamp itself. Don't depend on bumpers. Believe it or not, it's possible that they are rusted enough under the bolts that they are not grounded
RELAYS
Watch polarity on the coil connections. Some of these "Bosch" style relays have built in diodes across the coils, which is supposed to reduce damage to the switching circuit. This makes the coil polarity sensitive.
Sounds like you have it hooked up right.
Below is an example Pin 85 MUST be ground.
RELAYS
