MPG Decrease after replacing OE limited slip with Eaton Truetrac
Old 10-31-2014, 11:12 AM
jmhd1989's Avatar
jmhd1989
jmhd1989 is offline
Default MPG Decrease after replacing OE limited slip with Eaton Truetrac
So i had the common clips break off in my rear diff so i replaced the diff with the Detroit Locker Limited Slip Truetrac. my avg mpg was 12.2 now im getting 10.8. how would getting my rear end working properly lower my mpg?
Old 10-31-2014, 11:16 AM
jmhd1989's Avatar
jmhd1989
jmhd1989 is offline
just serviced it last week checked plenum repair i did earlier this year, looks clean still. K&N drop in air filter was still spotless. tire pressure is correct. only other thing i have done is removed side steps and replaced two inch springs with three inch springs. with the two inchers i was still getting the 12, would one more inch take 2 mpg away from me?
Old 10-31-2014, 01:13 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
Originally Posted by jmhd1989
.........how would getting my rear end working properly lower my mpg?
You answered your own question. The rear is working more now that there's a better traction aid. Both rear tires are more likely to turn under power in low traction situations. That will in turn make the engine work harder to turn the wheels.
Old 10-31-2014, 02:45 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Under normal circumstances, JUST changing the rear shouldn't affect economy quite that much. Wonder if your local gas station is now getting winter blend fuel?
Old 10-31-2014, 11:06 PM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
Maybe the gears are too tight with the new diff and something needs to be shimmed or adjusted?
Old 11-05-2014, 10:30 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
are you doing more 2 wheel burnouts?
Old 11-06-2014, 01:29 PM
jmhd1989's Avatar
jmhd1989
jmhd1989 is offline
ha i wish! i dont get to have any fun in it. i drive it like an 80 year old trying to make it last. smart, but zero fun
Old 11-06-2014, 01:50 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
No bad. Not smart. Drive the thing. Dont abuse it, but use it.
Old 11-06-2014, 10:16 PM
dhvaughan's Avatar
dhvaughan
what do you mean by replacing 2 inch springs with 3 inch springs? Are you talking about front end lift?
i suppose that by raising the front end you might be catching more air?
you didn't change tires did you? i lost 2 mpg going from an AT tire to an MT tire.
Old 11-07-2014, 10:58 AM
jmhd1989's Avatar
jmhd1989
jmhd1989 is offline
correct front end suspension. and that is what im worried about if it is down already ill be at 8 once i put on my new tires. one tire size up and to an AT from just a street tire.
Quick Reply: MPG Decrease after replacing OE limited slip with Eaton Truetrac
