The same size tires are on there now, there definitely not rubing, there loading up and slipping like im in four wheel, I dont know if not getting an alignment could throw everything off that much or not
You just made major changes to your front suspension geometry.... Inspect everything, replace what needs to be replaced, and get an alignment. If your tires are contacting anything, that should pretty much solve the issue.
